Results 1 to 13 of 13
    Default VW Golf ABS Coding help
    HELLO
    I have car VW golf 5 fsi I need code for ABS module MK60
    I have auto search by ross vcds
    I tray
    0021125
    0023174
    put not working
    Any one have help for this
    Germany
    Just take a look here: http://wiki.ross-tech.com/wiki/index...ctronics_(MK60) and try to build the coding yourself.
    Good luck.
    Greets MR...
  4. The Following User Says Thank You to brobble For This Useful Post:
    almlohe (26th January, 2019)
    Thanks for replying I am trying but not successful
    any help for this
    how i cane get coding from ross i try but not successful
    Coding
    ABS/EDS/ASR/ESP (MK60)
    • Model:
      • +0000000 = Audi A3 (8P) / Seat Leon (1P) / VW Golf/Jetta (1K)
      • +0000064 = VW Touran (1T)
      • +0000080 = VW Caddy (2K)
      • +0000096 = VW Eos (1F)
      • +0000112 = Seat Altea/Toledo (5P) / VW Golf Plus (5M)
    • Frontbrakes (Sensor Cluster OLD):
      • +0000005 = FS III 54 15" (PR-1ZF/1ZM/1ZC)
      • +0000006 = FN III 54 15"/16" (PR-1ZE/1LJ/1ZP/1ZD/1LL)
      • +0000009 = FRNG 57 17" (PR-1LK)
    • Frontbrakes (Sensor Cluster NEW):
      • +0000001 = FS III 54 15" (PR-1ZF/1ZM/1ZC)
      • +0000002 = FN III 54 15"/16" (PR-1ZE/1LJ/1ZP/1ZD/1LL)
      • +0000008 = FRNG 57 17" (PR-1LK)
    • Suspension:
      • +0000640 = Standard/Sport Suspension (PR-2UA/2UC OR PR-UA0/UA1/UA9)
      • +0001152 = Rough Road/Comfort Suspension (PR-2UB/2UD OR PR-UA2)
    • Engine:
      • +0002048 = 1.4l / 1.6l & 1.6l FSI
      • +0004096 = 1.9l TDI PD / 2.0l FSI / 2.0l SDI PD & All with Automatic Transmission
      • +0006144 = 2.0l TDI PD
    • Tire Pressure Monitoring (TPMS):
      • +0000000 = with Tire Pressure Monitoring (PR-7K1/7K6)
      • +0016384 = without Tire Pressure Monitoring (PR-7K0)
    Notes: See production codes on car data plate. Coding is the sum of the individual options.
    Sensor Cluster OLD: Installed behind glove compartment (ONLY VW Caddy (2K) & VW Touran (1T) & Audi A3 (8P) <MY2005).
    Sensor Cluster NEW: Installed under passenger seat (All Others & Audi A3 (8P) MY2006>).
    Special Notes: When replacing 1K0-907-379-D with 1K0-907-379-K or newer, the original Coding CANNOT be transferred to the new Control Module. Instead you need to build a new Coding using the Table above
    Germany
    At first look on car data label for the PR-numbers. Here you can identify the brake. Then you know your engine. I believe you have 1.6FSI, so 2048. Suspension will be standard, so 640. With or without tire pressure monitor I cant know from autoscan. Just look into data label. Letīs believe no, so add 16384. Model Golf, nothing to add. Little enginge means little brake. 15" is enough without power. :-) Sensor cluster new or old, I dont know, lets try both:
    0+1+640+2048+16384 = 0019073
    0+5+640+2048+16384 = 0019077
    Greets MR...
  9. The Following User Says Thank You to brobble For This Useful Post:
    almlohe (17th August, 2018)
  10. #8
    THANKS FOR THIS INFO I WILL TRAY AND TILL YOU
    THANKS
  11. #9
    its not working may bay abs ecu changing not right number i can get right number for this car WVWZZZ1KZ4W017772
  12. #10
    Jul 2016
    Vilnius
    Mate, your reputation in this forum is bad, maybe that's why nodoby wants to help? You seem to have done shameless things in the past
    * MK100
  13. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    almlohe (26th January, 2019), rafal (26th January, 2019)
  14. #11
    Why do you say this? I did not do anything bad to anyone
  15. #12
    any help for org number
  16. #13
    Portugal
    hello .
    Try this lonf Code.
    114B000C09230001001200EB901B00410000.
