At first, your eeprom of micro is not damaged. So you EIS is recoverable. You only need to find correct flash, which should not be a problem, because DK is full of them... :-)
Greets MR...
HI, MEMBERS , I NEED HELP, I READ WITH R-270 EIS W211 2115450608 , BUT DE EPROM AND FLASH ARE DEMAGED, I ATTACHED READING FILES,
AND I LOOK THE PROBLEM IS PRGRAMMER, BUYED VVDIPROG AND I READ ANOTHER IDENTICAL EIS AND PUT EPROM AND FLASH AND MAKE A KEY
TO FIRST EIS AND THIS EIS NOW WORK, BUT NOW I NEED RECOVER ORIGINAL EPROM AND FLASH, OR ANOTHER POSIBILTI, TO PROCED.
THANKS.
Greets MR...
rojhat (16th August, 2018)
Here is your flash. This should recover your EIS. It´s here from DK. Press thanks here: http://www.digital-kaos.co.uk/forums...ght=2115450608 to user karalada.
Good luck.
Greets MR...
HI, bROBBLE, EIS WORKS WITH SIMULATOR, AND KEY 8 FROM ORIGINAL EPROM DUMP , YOUR FILE WORK, THANKS, AND ANOTHER QUESTION, THE DATA STORED IN FLASH
ARE CHANGE SAME THING,FOR SAMPE KMS, CONFIGURAION, ETC...
SORRY FORMY BAD ENGLISH
I´m not sure, if I understand your question. KM, keys and configuration are only stored in eeprom. The flash never changes. Flash is firmware.
Greets MR...
treebug (17th August, 2018)
Ok Thanks for your time
