what problem you have with this car
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
I cant find correct software upg version with my ECU and i must make full backup from another car.
Backup made by KTAG.
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
What is cas eeprom ? Is it from ECU or from what ?
But i have ori keys with transponders and backup ori micro and OBD total read of extflash.
Do you have an idea how can i do this car working ?
What tools i need ?
I have TL866 II it is possible to read it by this tool ?
Another what i have is KTAG and KEss but i suppose in this case is usseles
Just rewrite your ecu to stock. With your original backup and make CAS-DME Allignment with proper tool. For example with ISTA-D, INPA, AVDI, FVDI, Launch and so on. If I understand you right, then you only lost synchronisation from CAS and DME by playing with full flash. For example if you read full backup with bdm, reinstall to car, start the car, take ecu out again and rewrite full backup, car can not start. If you want to update your ecu, just use WinKFP or ISTA-P and write it with obd, for example with cheap D-CAN cable or ICOM.
Greets MR...
Reality of life :
3:Everyone lies
But i havent full stock backup from my ecu because i write it via KESS by OBD and get ERROR.
When i next read full bdm backup i have chksum error that i suppose extflash data was damaged.
I havent full bdm of my STOCK ecu.
I havent xprog to
Then mate give up from this job and faind collegy ho work this profesional this is the best way
we can help you but you dont have tools
Reality of life :
3:Everyone lies
