Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    rafisoltys's Avatar
    Apr 2017
    Poland
    Default IMMO OFF in BMW E90 318d EDC16
    Could you help me with immobiliser off in ecu from BMW e91 318D ?
    Full beckup is attached.
    doctore's Avatar
    Nov 2015
    Colorado Denver
    what problem you have with this car
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    rafisoltys's Avatar
    Apr 2017
    Poland
    I cant find correct software upg version with my ECU and i must make full backup from another car.
    Backup made by KTAG.
    kiszka's Avatar
    Aug 2009
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by rafisoltys View Post
    post cas eprom
    rafisoltys's Avatar
    Apr 2017
    Poland
    What is cas eeprom ? Is it from ECU or from what ?
    Tunisia
    It is from CAS module ( black or gray box )
    rafisoltys's Avatar
    Apr 2017
    Poland
    But i have ori keys with transponders and backup ori micro and OBD total read of extflash.
    Do you have an idea how can i do this car working ?
    rafisoltys's Avatar
    Apr 2017
    Poland
    What tools i need ?
    I have TL866 II it is possible to read it by this tool ?
    Another what i have is KTAG and KEss but i suppose in this case is usseles
    Feb 2010
    Germany
    Just rewrite your ecu to stock. With your original backup and make CAS-DME Allignment with proper tool. For example with ISTA-D, INPA, AVDI, FVDI, Launch and so on. If I understand you right, then you only lost synchronisation from CAS and DME by playing with full flash. For example if you read full backup with bdm, reinstall to car, start the car, take ecu out again and rewrite full backup, car can not start. If you want to update your ecu, just use WinKFP or ISTA-P and write it with obd, for example with cheap D-CAN cable or ICOM.
    Greets MR...
  11. #11
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Yes i doo
    Remove cas unit read with xprog
    Or faind locksmith collegy to read for you if you dont have tools for this job
  12. #12
    kiszka's Avatar
    Aug 2009
    Reality of life :
    3:Everyone lies
  13. #13
    rafisoltys's Avatar
    Apr 2017
    Poland
    But i havent full stock backup from my ecu because i write it via KESS by OBD and get ERROR.
    When i next read full bdm backup i have chksum error that i suppose extflash data was damaged.
    I havent full bdm of my STOCK ecu.
    I havent xprog to
  14. #14
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Then mate give up from this job and faind collegy ho work this profesional this is the best way
    we can help you but you dont have tools
  15. #15
    kiszka's Avatar
    Aug 2009
    Reality of life :
    3:Everyone lies
