Results 1 to 10 of 10
    Aug 2018
    Default Passat B5.5 Speed from Gearbox to ABS.
    Hello I have AVF 1.9 TDI 96k and I changed my gearbox to another one from Superb which doesnt have wheel speed sensor. I am trying to program my Instrument Cluster for ABS sender but I am struggling.
    I know I need to change K-value and I did, then I need to adjust speedometer map and that I did aswell. The problem is that ABS is sending 4km/h speed to IC. Car "thinks" that its moving, and when I open the door it starts to alarm, fuel consumption doesnt switch from l/100km to l/h. I just dont know where to adjust this in eeprom.
    Pls help.
    My IC is VWK503 with code 3B0920849A.
    Apr 2020
    Hello friend, i have the same car and the same problem after changing gearbox.
    Did you resolve it? If Yes, how please?
    Thanks,
    Jakub
    Mar 2020
    in the field
    hello colleagues, just installing the drive saves you a simple matter I turned it into vw scharan
    Aug 2018
    Quote Originally Posted by hacek View Post
    Thanks,
    Jakub
    Hello, I solved the issue, but not in a way I wanted. I ll send u DM.
    Meat-Head's Avatar
    Quote Originally Posted by Chepa View Post
    Err why by private? Dk is a caring sharing forum
    Aug 2018
    Just asking because this is interesting problem... I have 3B0920829A cluster and vcds coding info say that k-value 1 = speed signal via CAN (23400). This doesn't work with 849A as should? Without messing with eeprom values. If speed is constantly 4km/h it sounds like 4 abs sensors sending 1km/h to indicate they are ok.
    Meat-Head's Avatar
    Just as a reference we find when working on ANY car first gear let it run at idle about 7 km/ph
    kiszka's Avatar
    Aug 2009
    Pls help.
    Does the car have CAN lines?
    if it is not there, one ABS wire must be added
    and output a speed signal to the meter
    I think that nothing needs to be changed in the meter
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
    Apr 2020
    Hi, my car has a CAN BUS. It is VW Passat b5.5, year 2004, 1.9 tdi 96 kW AVF. I tried to find solution, why are clusters showing speed 4km/h when car is stopped.
    When i changed the value on address 065 from 80 (gearbox sender) to 81 (abs sender) and save, then during witing new eeprom to instruments moved speed needle to 4km/h. Before this change was this needle on 0km/h (when cas was stopped). I tried make some correction (via dash dump edit) but without success.
    94064509_2659916707452843_917415472670965760_n.jpg93695811_2659916664119514_1350248099074801664_n.jpg
    Jun 2023
    hello mate i have problem too speed is not showing i want to change from canbus to abs speed
