Hello friend, i have the same car and the same problem after changing gearbox.
Did you resolve it? If Yes, how please?
Thanks,
Jakub
Hello I have AVF 1.9 TDI 96k and I changed my gearbox to another one from Superb which doesnt have wheel speed sensor. I am trying to program my Instrument Cluster for ABS sender but I am struggling.
I know I need to change K-value and I did, then I need to adjust speedometer map and that I did aswell. The problem is that ABS is sending 4km/h speed to IC. Car "thinks" that its moving, and when I open the door it starts to alarm, fuel consumption doesnt switch from l/100km to l/h. I just dont know where to adjust this in eeprom.
Pls help.
My IC is VWK503 with code 3B0920849A.
Thanks,
Jakub
hello colleagues, just installing the drive saves you a simple matter I turned it into vw scharan
Just asking because this is interesting problem... I have 3B0920829A cluster and vcds coding info say that k-value 1 = speed signal via CAN (23400). This doesn't work with 849A as should? Without messing with eeprom values. If speed is constantly 4km/h it sounds like 4 abs sensors sending 1km/h to indicate they are ok.
Just as a reference we find when working on ANY car first gear let it run at idle about 7 km/ph
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
Hi, my car has a CAN BUS. It is VW Passat b5.5, year 2004, 1.9 tdi 96 kW AVF. I tried to find solution, why are clusters showing speed 4km/h when car is stopped.
When i changed the value on address 065 from 80 (gearbox sender) to 81 (abs sender) and save, then during witing new eeprom to instruments moved speed needle to 4km/h. Before this change was this needle on 0km/h (when cas was stopped). I tried make some correction (via dash dump edit) but without success.
94064509_2659916707452843_917415472670965760_n.jpg93695811_2659916664119514_1350248099074801664_n.jpg
hello mate i have problem too speed is not showing i want to change from canbus to abs speed
