Help,yd22
Results 1 to 3 of 3
Thread: Help,yd22
    Jan 2014
    South Africa
    Default Help,yd22
    Hi everyone,is anyone familiar with a yd 22 t30nissan xtrail ,just cant seem to find whats wrong ,engine was replaced and vehicle does not start,and np fault code present,immo light goes off,and diesel pressure on start looks fine.any help will be appreciated
    Jul 2013
    yorkshire
    "fuel pressure looks fine" is not good enough, put them up and lets see. Do you have cam/crank sync? Do you have good ground and a good 5v ref at sensors.
  3. The Following User Says Thank You to autoden For This Useful Post:
    shinehead (5th September, 2018)
    Jan 2014
    South Africa
    Hi,thanks for reply,like i was saying theres no fault code present,no cam and crank sync fault,still battling with it,phoned the diesel services and was told ,if the engine is an import the diesel pumps are different and will never start ,i need to use the pump from old engine.can one confirm this .
    Thank you
