Results 1 to 8 of 8
    Default Bmw cas Flash file
    Hi has anybody got a flash file for this cas the battery has shorted and took the cas and dme but cant program it without cas flash working thanks
    doctore's Avatar
    Nov 2015
    Colorado Denver
    do you have ignition on or not
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    No ignition and original flash file has very little data in it eeprom looks fine though here are original files
    magneto21's Avatar
    Jul 2016
    there u go..........
    “The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice.”
  5. The Following User Says Thank You to magneto21 For This Useful Post:
    doctore (16th August, 2018)
    magneto21's Avatar
    Jul 2016
    looks like the flash is corrupted
    load the flash I send you, and see what happens!
    Thankyou appreciate the help will let you know
    That flash is wrong.
    This is correct:
    WBR, Marek
  9. The Following 5 Users Say Thank You to tech_cz For This Useful Post:
    brend (21st August, 2018), doctore (17th August, 2018), dritan (17th August, 2018), sagie (17th August, 2018), vasa (17th August, 2018)
  10. #8
    Thanks for the help will let you know
