Results 1 to 15 of 26
Thread: lancer evo 7
    Default lancer evo 7
    hi I have never lost a file but im blaming my adapter I have lost the file for this car its a a 93c56 chip set if ne one has a dump I would really help on this problem it a Mitsubishi lancer evo7 itis a 93c56 chipset ne where near 43000k thank u in advance
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Do you have some more specific info or photo as a reference????
    Maybe i can help you...
    Sent from my SM-J710GN using Tapatalk
    if you think i helped youkindly press REP+THANKS button
    all I have is Mitsubishi lancer evo 7 with 93c56 chipset
    Jul 2015
    hi mike thanks for the help but I cannot get it from the drop box is there ne other way to send or maybe post on here again thank u for your help
    clusters's Avatar
    Mar 2015
    Canada
    You could have if you waited a bit, I did.
    Sep 2018
    Italia
    Hallo,
    I'm intreted on this thread too...
    I've got a evo 9 dashboard in Km (imperial) with eeprom 96c56 corrupted: while reading with Ponyprog 2000 got sone bits faild... rewrite with the same errors and now the odo display doesn't shows nothing at all.
    May be a checksum error that lock the dashboard startup?
    please help me...
    Jul 2015
    Quote Originally Posted by Floppyz View Post
    Hallo,
    please help me...
    No checksum - just bad dump. Have you tried the Evo 7 one above? Should work otherwise I have a 9 one at work.
    Sep 2018
    Italia
    Hi Mike, yes I tried the evo 7 above but nothing, still blank odo display.
    My dashborad is EDM obviusly, maybe the evo 7 JDM dump is in miles?
    tks
    Sep 2018
    Italia
    Sorry errata corrige:
    my eeprpm is a 93c56! not a 96c56 (that naither exist...)
    Jul 2015
    Ok - will post an Evo 9 dump tomorrow for you. JDM in kms.
    Apr 2018
    EU
    tks
    Try to flip bytes.
  13. The Following User Says Thank You to Diagcar1 For This Useful Post:
    Floppyz (12th September, 2018)
  14. #13
    Sep 2018
    Italia
    Quote Originally Posted by Diagcar1 View Post
    Try to flip bytes.
    Swap byte do you mean? I'll try today.
    Does anyone have test ponyprog 2000? useing serial-usb converter and direct probe for microwire 16 byte config.F3MZKDIIRXSZ4JF.LARGE.jpg
    Pin 6 and 7 connected to +5V
  15. #14
    Sep 2018
    Italia
    Try to flip bytes.
    OK GOT IT!!
    now I can see right mileage useing same evo 7 file posted above!
    Thant to all of you!
  16. #15
    Sep 2018
    Italia
    Sorry I bother you agian, but now i have new problem:
    now I have flash the eeprom with the evo 7 dump posted above
    - Speedometer lost linearity: before reflash eeprom it indicate 145km/h @ 100Hz signal on pin 12.
    now if I realing the needle to 145kmh at 100hz and move frequncy to 50Hz it indicate 40 kmh (not half 145 -> 77 as I supposed...)
    here what I read now:
    Hz --- km/h
    45 --- 20
    55 --- 40
    71.5 --- 80
    91 --- 120
    110 --- 160
    How can I calibrate it?
    Also fuel level do something odd.....
