Resolder Flash
On Mercedes W203 SIM4LE same problem with Flash soldering.
Need solder many Times
Problem is Car cant find ECU! ;-)
HI
i have volvo XC90 D5 Engine ECU BOSCH Control Unit 0281011441 1039s04101 30646978A
after reflache 29f400 (EGR problem) car not start i reflache with original file and many other file but same
pb
i tested all wires is ok
i find also +5v in all sensors
now i have this DTC ECM-8410 / ECM-2700 / ECM-1300 / ECM-8420 / ECM-1400 / ECM-200 / ECM-1000
can someone have a solution or how can repair ecu if is the pb
thx
Resolder Flash
Hi M8,
Send me the files to check what happend, will help you.
Regards.
Chiptuning file services ,custom remaps, inmo off, egr off, dpf off, adblue off, flaps off, tva off, lambda off, speed limit, selective dtc´s deleting ,etc.
Worldwide assistance.
All brands, All vehicles, All files.
If only happens after reflash,confirm soldering and clean very well all contacts and pcb.
Files could be damage,backup,post it,jnoroestewill confirm to you
this is orginal file & mod file
You can read en write this ecu with mpps or fgtech in boot
if fan starts the ecu have no contact with eeprom
hallo
try this original file
quikcar (18th August, 2018)
Happend to me.
I transfered eeprom, and wrote flash on secondehand ECU.
Possible used wrong voltage pin out in my case.
I think ecu broken 100%
Best way to read this ECU with boot mode
I will buy an other used ecu I will change 5p08c3 eeprom
I hope car work now
Thanks for help
Sent from my PGN611 using Tapatalk
