Results 1 to 9 of 9
    Feb 2018
    Hungary
    Default Citroen C5 BSI flash file needed
    Hi All!
    FVDI killed the BSI(milage correction).
    I need flash file.
    THX for the help!
    Citroen C5 2009
    donkez's Avatar
    Mayo, Ireland
    put FFFF's in 95128 eeprom and program it from new with Lexia
  3. The Following User Says Thank You to donkez For This Useful Post:
    Cunder79 (17th August, 2018)
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by Cunder79 View Post
    Hi All!
    I need flash file.
    THX for the help!
    Citroen C5 2009
    post software signature
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by donkez View Post
    and wat will doo when fill eprom with fff
    and not have ignition on car
    donkez's Avatar
    Mayo, Ireland
    Quote Originally Posted by doctore View Post
    done good few BSI's that way, there is an ignition, just anti theft active. Program the code, options and off you go. Unless it is some special BSI....
    doctore's Avatar
    Nov 2015
    Colorado Denver
    only need flash donkez nothing more to save money
    bsi can bay if cannot faind software signature same
    and all by ok
    I check tomoro for jci F3E4
  8. The Following 2 Users Say Thank You to doctore For This Useful Post:
    Cunder79 (17th August, 2018), figani (17th August, 2018)
  9. #7
    Feb 2018
    Hungary
    Here is the damaged file.
  10. #8
    Feb 2018
    Hungary
    Solved! Help is ready!
  11. #9
    doctore's Avatar
    Nov 2015
    Colorado Denver
    do you faind good flash
    i dont have this number you can post here
