VALTRA T180 dashboard Hours?
Results 1 to 4 of 4
    Aug 2015
    Default VALTRA T180 dashboard Hours?
    Hi !
    I need help with tractor VALTRA T180 dashboard . Dashboard is broken.
    Inside eeprom 25c040
    Need to know motor hours???
    Dump in attach..
    Thanks!
    Quote Originally Posted by ugoxx View Post
    Hi !
    Thanks!
    546,8 hours
    But your dump is corrupted: shifting by one byte...
  3. The Following User Says Thank You to Amats For This Useful Post:
    jomberykaso (2nd September, 2018)
    Aug 2015
    Hi !
    Meybe do you have correct eeprom for this tractor VALTRA T180 proline display
    I need flash image for 29F200B too, the same tractor.
    Sorry, I had a mistake with your dump's hours.
    I have a corect dump with knew hours (533,9 hours), but unfortunately I do not know correct algo for this cluster. I will be thank if anybody will help me with my dump or give me own dump. I need 6300 hours.
    Thank you.
