cloning might be an options!
paulsta (19th August, 2018)
We have no key to clone, is this my only option?
Cheers
Sent from my Pixel 2 XL using Tapatalk
If i helped please press the thanks button
2015-2016
PATS CAN BCMII 4
Seems to be possible.
is there a way of reading the original stored keys that are lost?
eeprom i assume
not sure of target chip tho
Same here, I'm hoping someone can help me?
Cheers
Connect is the same as Fiesta, AD100/MVP pro makes it easy and can see how many keys and clear. AVDI can also
I was hoping to be able to write the transponders to match the stored keys, is this possible?
Cheers again for the help
Key is in relation with
BCM, PCM, ABS.....
Somtime need hour or two to add key
Can I dump the bcm and read the existing keys? Is this what you are saying?
Thank you
does anyone else know if this is possible, I might be asking something silly here but i am learning and will always give feedback of what i have done,
Cheers
Must be an eeprom or MCU to tackle somewhere?
What country are you in? Most in the US don’t have the transponder system enabled. The RHK keys are 40bit integrated 4D but can be converted to 80bit with the vvdi key tool to use either way. The remote system is OBP.
