Results 1 to 11 of 11
    Aug 2018
    Default Corsa D 13256903 help in removing crasch
    Cześć. Potrzebuję pomocy w usuwaniu crasch.
    Corsa D Temic 13256903 327963935
    Dziękuję bardzo
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Where is your file from eeprom 95160 ?
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
    hudy26's Avatar
    May 2017
    Poland
    Default ok
    test and give a report
    dragon100's Avatar
    Jan 2012
    I see my browser no fresh :-)
    Best regards.
    Dragon
    Oct 2016
    hi
    Please click here
    Aug 2018
    Thank you very much for your help. The file works only it is not under my car. Only front pillows are active. There are side cushions and curtains in my car. I would need a file for this configuration. thank you
    dragon100's Avatar
    Jan 2012
    Read your original file from eeprom 95160 and upload here ...
    Best regards.
    Dragon
    Nov 2015
    Default Corsa D clear
    Clear File,Tested.
  9. The Following User Says Thank You to airbag 123 For This Useful Post:
    juanes 3 (27th July, 2020)
  10. #9
    Aug 2018
    The driver is not from this car, therefore I do not have the original file
  11. #10
    dragon100's Avatar
    Jan 2012
    Best regards.
    Dragon
  12. #11
    Aug 2018
    I tested the file from the link. It also has 2 pillows configured. Needed file from the new driver or configuration for 6 pillows
