DSG TUNING
File Service
How do you made this file ? Manually or with automatic software.
Have also a Z17DTR with DPF off but i think to many errors are disabled
chli1976 (20th August, 2018)
Can someone help me to fix this file?
Post you ori FILE...
DSG TUNING
File Service
This is ori file
No need to recode dash, need only from correct DPF OFF solution and DPF reset before write.
100% correct, tested the same software before 2-3 years.
BR
All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
Our database available for download 24/7 on EVC server for all legal WinOLS users
chli1976 (22nd August, 2018), garibaron (2nd October, 2023), gefi (5th May, 2019), liban11 (20th November, 2018), mistergame (20th August, 2018)
Before writing I have to do a forced regeneration? I have to write the file after I have to detach the sensor?
Use diagnose tool and make DPF reset ( DPF changed with new ) ... or make regeneration. After writing file you can disconnect the sensors or leave it connected ... as you want.
BR
Okay, thanks as soon as I write the file I will inform you
today I wrote the file everything works fine thanks so much
Can you give me a pass. Thanks.
Hi !
( 2007 ) Opel / Vauxhall 1.7 CDTI ( 101 Hp. )
Engine code: Z17DTH
How to decode the EGR system ?
Is it possible to do such a thing with VCX NANO ?
...because a friend of mine has one for GM vehicles.
HELP is gratefully received !
