ANy hawe solution? i tried dtc off but hawe 1500 RPM. Tried reflash full bdm from other ecu and same fault?
If I help You. please say THANKS.
I also have this error, car starts but poor rpm,have tried reflash too but still the same fault ,ecu had very slight water damage , has anyone managed to trace where this problem lies as I'm having no success locating a replacement unit, thanks.
Sent from my E6653 using Tapatalk
any info about this fault??
i changed L9132 and L9131 and one 5volt regulator but still same issue
It happens that i have one with same issue too
If i Helped you,use thanks and rep button to thank me back
