Results 1 to 2 of 2
    ivanmihov's Avatar
    Nov 2016
    Europe
    Default VW Golf 5 1.6 FSI need DTC OFF
    Hello friends, i need dtc off for this VW Golf 5 1.6 FSI ecu Med 9.5.10
    car had problem with NOX sensor,so a member from forum made me nox off,car was fine for about two months,and now mil is ON fault is
    18528 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
    P2096 - 002 - Too Lean - MIL ON
    car is not in limp mode just Mil is On i can delete fault but is coming back in a few days
    can someone help with DTC OFF
    thanks in advance
    here are files original and nox off
    soundnavigator's Avatar
    Sep 2010
    Your file DECAT and NOX OFF.
    BR
    All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
    Our database available for download 24/7 on EVC server for all legal WinOLS users
  3. The Following User Says Thank You to soundnavigator For This Useful Post:
    ivanmihov (20th August, 2018)
