Results 1 to 10 of 10
    Jul 2012
    Default Volvo S80 2.5D ECU - CEM sych
    Hello, i have a Volvo S80 2.5d with the famous VAG engine. There is a fault code in the ECU - wrong immo code. Need to sych the ECU and CEM. VolvoSynchro V1.4 - recognizes the CEM file, but with ECU says "BAD CU FILE". Could someone please sych there two modules with the original keys remaining.
    ECU - 0281001776 - 24c04
    Thank you
    MartiLer's Avatar
    Dec 2016
    poorly read 28F400. at address 8000 should be VIN. read it again.
    qwertyuiop12's Avatar
    May 2013
    Hi all,please help,Volvo S80 2001 after battary dead car not start,not crank.
    I read CEM28f400 and ECU 5p08,
    in CEM not keys and sinhro,I try codecard soft Volvo 1.4,
    car crank but not start.
    Please help sinhro ECU with CEM.
    My original dumps.
    Original key
    UM:5388877A
    MartiLer's Avatar
    Dec 2016
    need to write new keys. and make the synchronization manual. utility 1.4 does not correctly.
  5. The Following User Says Thank You to MartiLer For This Useful Post:
    qwertyuiop12 (18th October, 2018)
    May 2013
    I make new key with carprog,than make sinhro manual,but car crank,and not start.
    This my sinhro.
    May 2013
    Can anyone check the correct sync or not.
    soxten's Avatar
    Mar 2013
    Make virgin and reload with Vida online!
    Skickat från min iPhone med Tapatalk
  9. The Following User Says Thank You to soxten For This Useful Post:
  10. #8
    May 2013
    I still need help.
  11. #9
    Oct 2015
    Quote Originally Posted by qwertyuiop12 View Post
    I still need help.
    make new transponder for this new set. i dont know about carprog.
    VOLVO S80 complet ok.rar
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  12. The Following 2 Users Say Thank You to rokibar For This Useful Post:
    alclot (7th November, 2018), qwertyuiop12 (20th October, 2018)
  13. #10
    Aivis3's Avatar
    Sep 2016
    Latvia
    This my sinhro.
    Sync 00291426748353208500 (Correct)
    Key1: 20DB6438
    Key2: 1A86F0F8
    Key3: 20BF4D43
    Check keys! CEM see keys correct?
    Check faults in CEM and ECM
    If helped - "Thanks" and "Reputation" please
  14. The Following User Says Thank You to Aivis3 For This Useful Post:
    qwertyuiop12 (23rd December, 2018)
