poorly read 28F400. at address 8000 should be VIN. read it again.
Hello, i have a Volvo S80 2.5d with the famous VAG engine. There is a fault code in the ECU - wrong immo code. Need to sych the ECU and CEM. VolvoSynchro V1.4 - recognizes the CEM file, but with ECU says "BAD CU FILE". Could someone please sych there two modules with the original keys remaining.
ECU - 0281001776 - 24c04
Thank you
Hi all,please help,Volvo S80 2001 after battary dead car not start,not crank.
I read CEM28f400 and ECU 5p08,
in CEM not keys and sinhro,I try codecard soft Volvo 1.4,
car crank but not start.
Please help sinhro ECU with CEM.
My original dumps.
Original key
UM:5388877A
need to write new keys. and make the synchronization manual. utility 1.4 does not correctly.
qwertyuiop12 (18th October, 2018)
I make new key with carprog,than make sinhro manual,but car crank,and not start.
This my sinhro.
Can anyone check the correct sync or not.
Make virgin and reload with Vida online!
Skickat från min iPhone med Tapatalk
I still need help.
make new transponder for this new set. i dont know about carprog.
VOLVO S80 complet ok.rar
6841707059 576F526B 57416E5453 596F55 526F6B69424152
alclot (7th November, 2018), qwertyuiop12 (20th October, 2018)
qwertyuiop12 (23rd December, 2018)
