Results 1 to 3 of 3
    Nov 2011
    Default which coding for ABS unti in VW TIGUAN 2010 - 5N
    I have VW TIGUAN.
    the ABS has lost original coding - actual coding = "0010000"
    ("c4" / short coding // not "c6" with long coding !! )
    somebody can obtain the correct coding ???
    (adaption and basic settings are no problem, only the coding i need)
    5N TIGUAN is unfortunately not listed in VCDS to calculate the correct coding...
    next codes i try, and not work :
    5161 / 5953 / 5950 / 5947 / 2104 / 5173 / 7215
    Brand VOLKSWAGEN
    Model TIGUAN 4MOTION
    VIN WVGZZZ5NZAW096042
    Production date 2010-04-12
    Model year 2010
    Engine code CBAA
    Engine volume, L 2.00
    Number of cylinders 4
    Power, KW 100
    Power, PS 136
    Address 03: ABS Brakes Labels: 5N0-614-109-C4.clb
    Part No SW: 5N0 614 109 M HW: 5N0 614 109 M
    Component: J104 C4 450 V2F1 0003
    Revision: --H28--- Serial number: 00000002698462
    Coding: 0010000
    Shop #: WSC 01324 020 00200
    VCID: 3565D9195CDE9FECC4-8060
    Athens
    32768 - start-stop (7L6)
    16384 - start-stop or coasting?
    4096 - indirect tire pressure monitoring
    2048 - right wheel
    512 - Off Road
    256 - rear ABS sensors gray for PLA2
    engine and transmission combination:
    1029 - 1.4tsi 75 - 100kW front-wheel drive manual transmission
    1032 - 1.4tsi 75 - 100kW front-wheel drive manual transmission (China)
    1035 - 1.4tsi 101 - 130kW front-wheel drive manual transmission
    1038 - 1.4tsi 101 - 130kW manual transmission 4Motion
    1041 - 1.8tsi 105 - 130kW front-wheel drive manual transmission (China)
    1044 - 1.8tsi 105 - 130kW front-wheel drive automatic (China)
    1047 - 1.8tsi 105 - 130kW automatic transmission 4Motion (China)
    1050 - 2.0tsi 125 - 160kW automatic transmission 4Motion (China)
    1053 - 1.4tsi 101 - 130kW DSG front-wheel drive (NAR)
    1056 - 2.0tsi 125 - 160kW DSG 4Motion (CCZD motor 132kW)
    1059 - 2.0tsi 125 - 160kW front-wheel drive manual transmission (NAR)
    1062 - 2.0tsi 125 - 160kW front-wheel drive automatic (NAR)
    1065 - 2.0tsi 125 - 160kW automatic transmission 4Motion (NAR)
    1068 - 2.0tsi 125 - 160kW manual transmission 4Motion
    1071 - 2.0tsi 125 - 160kW DSG 4Motion
    1074 - 2.0tsi 125 - 160kW automatic transmission 4Motion
    1077 - 2.0tsi 125 - 160kW front-wheel drive manual transmission (NAR)
    1080 - 2.0tdi 70 - 90kW front-wheel drive manual transmission
    1083 - 2.0tdi 91 - 110kW front-wheel drive manual transmission
    1086 - 2.0tdi 91 - 110kW manual transmission 4Motion
    1089 - 2.0tdi 91 - 110kW DSG 4Motion
    1092 - 2.0tdi 91 - 110kW automatic transmission 4Motion
    1095 - 2.0tdi 111 - 130kW DSG 4Motion
    1098 - 2.0tdi 111 - 130kW manual transmission 4Motion
    1101 - 1.4tsi 101 - 130kW DSG front-wheel drive
    For example I have a 2.0 diesel with automatic transmission with 4x4 off road, indirect tire pressure monitoring and PLA2:
    4096 + 512 + 256 + 1092 = 5956, coding is 0005956.
    May 2021
    Canada
    Did you find any solution? looking for coding my C4 module.
