HI TEST THIS VIRGIN IT IS MADE FROM YOUR ORG FILE
PIN: C32V OR V23C
GOOD LUCK
Hi friends,
I have a Peugeot 307 2.0i 2004, engine type RFN, this car came to me with orig BSI damaged and with new ECU SET came from donor car from UK RHD, this is LHD...
All parts have same parts numbers, old and donors parts (ECU,BSI+key), engine worked normally but some funtion doesnt worked well.
So, i made BSI virgin with dump sent by Zmann, but i cant finish it because when i try to made INITIALISATION-LEARNING PIN CODE but cant be done, i received this menssage annex pic bellow, and BSI continue in blank mode i cant learn BSI or add key.
Annex orig dump to confirm if my pin code is correct
Using PP2000 V7.57
Thanks in advance
Cheers
Press "THANKS" button. just one click, CHEERS
PIN: C32V OR V23C
GOOD LUCK
electrones (7th September, 2018)
CHIKO (7th September, 2018)
C3V2 PIN COD
Hi friend
Thanks again for your attention and collaboration , yes i follow PDF config and made some changes on car in some absent or present items but prob is when i try to initialization-learn mode it canīt be done i dont know why...
I thought it was the pin code, but pin code is ok C32V because i put backup to BSI and add key it work well, pin code successfully
iīll try to day again and report
Cheers
HI if your org bsi for exemple is J05 you need a new one J05 if you put J03 or J04 you will lose some fanction in your car
if this is your problem dont waste your time get your org bsi NW/SW and evry think will be back
good luck
friend would have the reading of this ecu unless I need a file with this numbering thanks
Hi chico
Thanks for your help and collaboration friend , but your virgin dump is not ok, no dash ON, one relay in BSI clicking with ignition on position 2,but i put back original dump everything work well
About BSI is al same parts annex to take a look
hi douglas
Thanks for your attention friend
Annex pics
Cheers
Thanks in advance
CHIKO (9th September, 2018)
friend writes this file and generates a new t19
electrones (20th September, 2018)
HI i will check the file later
for your car you dont need a virgin file just clone the new bsi
good luck
Thanks guys probs solved, no need made BSI virgin for me, only change some parameters on present and absent and other work ok for me now everything work normally
THanks all of you who help me here and by mail
Cheers
