Results 1 to 5 of 5
    donkez's Avatar
    Mayo, Ireland
    Default solution for U0118 fault on Ford Focus
    Somebody might find it useful.
    Lately got a few focuses with the same u0118 fault, no comms with aditive module, so decided to look into it. Noticed in forum that it is quite common.
    Got the module out from under the rear seat, and found there is no continuity between two through holes. check pictures for repair.
  2. The Following 6 Users Say Thank You to donkez For This Useful Post:
    autocargo (26th September, 2021), danielif (26th September, 2021), ditk (29th December, 2023), Dunker (14th September, 2018), Mondeost (25th September, 2021), morfej (24th August, 2020)
  3. #2
    Dunker's Avatar
    Yorkshire
    Wonder if it's caused by the cap leaking ?
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  4. The Following User Says Thank You to Dunker For This Useful Post:
  5. #3
    donkez's Avatar
    Mayo, Ireland
    dont know, but there was fuel cap fault sored in it when it was back on line.
  6. #4
    Feb 2018
    From one Mayo man to another, thanks so much
    May 2022
    Hi,I can not open that pictures.
