Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Top Poster lexidime's Avatar
    Jun 2017
    Upstate
    Default Don't Let Customers Punk You In Charging low/How to wake Up a MCU in protection Mode
    If a client comes to you for this type of service: he or she really needs it. Our services are not luxury items! These clients comes to you out of necessity or desperation! Bill accordingly!
    Here's a nice weird story: a person calls for a correction on a 2016 lexus RC. We gave our labor and they replied that they received an 80 quote elsewhere; if we could do better. We told them "sorry but we can't match that number"
    2 days later a guy calls us about the same year, make and model. Saying that he's a professional corrector and he'll give us 250 to help him figure out an issue with a dash. He says after he programmed it, the cluster went dead! We asked him what tool did he use. He said a digiprog3
    So we told him to bring the car and the cluster. It turns out that this car belonged to the same customer that called with that low ball 80# The corrector used a clone digiprog 3 to try to do the 2016 lexus rc350 from the lexus drop down menu on his 2009 DP3.
    So we removed the c66. Reflash it with a new dump - "no correction"
    cluster - still nothing! > Installed a brand new c66 same thing
    . To make a long story short these MCU have a feature call "COP" "LOL" it stands for ( Computer Operating Properly Reset). It will shut down the MCU if it receive corrupt data that will compromise the operating memory programmed in the MCU, not the external EEprom. To reset it depends on the MCU. Some is a simple reset pin held High or low for the amount of clock cycles stated on the data sheet or you will have to raise the reset and clock pin on the board power up the MCU only and feed the SRST + SCL on both pins using a function generator which was the case for this lexus and it worked also good for dead Audi clusters too. 16mhz for 32 clock cycles. all is well save the guy $2,286.55. He didn't even know that his $100 digiprog is a cheap clone. We test it on a few boards and it failed! it couldn't even do a 68HC912B32 or a NEC uPD780973. When he saw the results; he took it and smashed it to pieces on the ground. never a dull day at work.
    Moral of the story is to show you one prime example out of so many how going cheap can go so wrong
    . Just buy all original tool they offer good Tech Support! The Cheapest providers are always never respected! IE APPLE VS ACER. As your reputation goes up so will your clientele. Word of mouth will supersede any advertisement. Always quote base on the value of your service to cover your expenses + to grow your tool library :Air removal tools, pencil irons, oscilloscope, function generator ,multi meters, controlled power supplies, spectrum analyzer, plus original correction gear! If we didn't have these diagnostic tools to measure the behavior of this cluster it would have been tossed in the trash and cost the customer and/or corrector over $2k
  2. The Following 15 Users Say Thank You to lexidime For This Useful Post:
    ascrap2003 (14th September, 2018), bearheroes (14th September, 2018), blackpirate (13th September, 2018), brend (13th September, 2018), dashradio (22nd September, 2018), dunnnia (16th July, 2019), i_shot_the_sheriff (14th September, 2018), Mario3 (22nd September, 2018), MasterCodein (19th September, 2019), Meat-Head (23rd September, 2018), nickolasd (13th September, 2018), norbisko (23rd January, 2019), rafal (22nd September, 2018), rikko (13th September, 2018), samux (13th September, 2018)
  3. #2
    brend's Avatar
    Oct 2015
    Same where
    NB!!! Don't ask in PM old file password , Im not remember.
  4. The Following User Says Thank You to brend For This Useful Post:
    lexidime (22nd September, 2018)
  5. #3
    brend's Avatar
    Oct 2015
    Same where
  6. The Following User Says Thank You to brend For This Useful Post:
  7. #4
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by lexidime View Post
    I see damaged clusters many times, they are begging me for help, they offer me $$$$$$$'s, i never help them out. Even if it's a easy fix. The only way to let them think and stop. If i get a expensive car to do, i first check if the car works 100%, if someone else ''played'' with it i sent the customer away.
  8. The Following 2 Users Say Thank You to drpeter For This Useful Post:
    brend (13th September, 2018), DARFVADER (23rd September, 2018)
  9. #5
    brend's Avatar
    Oct 2015
    Same where
    I think moral of the story is, if you try help this people you just lose time which = $$$$$$.Because no guaranty like damaged modul wake up.
  10. #6
    ascrap2003's Avatar
    Sep 2016
    Texas
    Well said, I hate cheap people!
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
  11. The Following User Says Thank You to ascrap2003 For This Useful Post:
  12. #7
    i_shot_the_sheriff's Avatar
    Nov 2008
    Respect ...... well said ! We encounter this everyday ...
    Dpf off service with china Kess -> 50Euro ................ ecu goes bad ,,,,,, client pays 250 Euro for used ecu and coding ,,,,,
    YOU ARE THE BOSS IN YOUR OWN BUSINESS,,, NOT THE CLIENT OR THE MARKET !
  13. The Following User Says Thank You to i_shot_the_sheriff For This Useful Post:
  14. #8
    Jun 2017
    Upstate
    Quote Originally Posted by drpeter View Post
    Yes a client came with their PCB burn at the eeprom location all the pads were lifted off the board
    Sent from my N9137 using Tapatalk
  15. #9
    Jun 2017
    Upstate
    Quote Originally Posted by ascrap2003 View Post
    Lol they love to say, can you lower your fee this time and I'll bring you lots of business. Reply pay the regular rate now and when you come back you'll get lots of discounts
  16. The Following User Says Thank You to lexidime For This Useful Post:
    H2Deetoo (23rd September, 2018)
  17. #10
    Jun 2017
    Upstate
    Even the microchips inside the clone tools are clones lo
    Quote Originally Posted by i_shot_the_sheriff View Post
  18. #11
    Feb 2017
    Baltic
    Lots of customers lie about prices elsewhere. There was an occasion where one guy said that there is somebody who does year old jap cars for like 40usd. Few weeks later the same guy called from other number and agreed on the original said price . There was newer merc that I did long time ago. The customer forgot the mention that car had been to like 4 different mileagemen before me and they were unsuccesful (luckily no damage done with their cheapest china clones) with mileage correction . Lots of people ask about ECU and other module km correction, since those digiwigi specialists cant do that. Easiest to tell customers that sorry, can t do that, since the car is broken because some other guys touched it . Next time they will think about going to those cheapest of the cheapest guys .
    In my are there are guys who know lots of stuff and all of those guys know each other and everybody does things for basically the same prices, except for digiwigi masters .
  19. #12
    Dec 2016
    central uk
    favourite is well i dont want much off so it will be cheaper ...
  20. #13
    Jun 2017
    Upstate
    The worst part is that the guy in my area if they burn a cluster they will runaway leaving the customer stranded
  21. #14
    Jun 2017
    Upstate
    yes wow
  22. #15
    Meat-Head's Avatar
    . To make a long story short these MCU have a feature call "COP" "LOL" it stands for ( Computer Operating Properly Reset). It will shut down the MCU if it receive corrupt data that will compromise the operating memory programmed in the MCU, not the external EEprom. To reset it depends on the MCU. Some is a simple reset pin held High or low for the amount of clock cycles stated on the data sheet or you will have to raise the reset and clock pin on the board power up the MCU only and feed the SRST + SCL on both pins using a function generator which was the case for this lexus and it worked also good for dead Audi clusters too. 16mhz for 32 clock cycles. all is well.k
    great story, would you mind adding tiny bit of info on Audi clusters to a thread nearly ten years old
    the car in question has proberbly been made into 6 washingmavhines twice by now
    http://www.digital-kaos.co.uk/forums...l=1#post433669
