Results 1 to 2 of 2
    Feb 2022
    Georgia
    Default DS150E Hardware/Software problem?
    Could anyone help me with this issue? When connecterd to any car or bench ecu it can not get connected! It flashes lights, clicks relays but the result is the same - can't connect to the vehicle.
    It passes test in Settings everything seems ok. I tried to reflash it but the result is the same
    Its two-boarded if it matters...
    Any help is appreciated, thank you
    Feb 2018
    Poland
    Which version are you using? What is your device number in device settings? Have you tried clicking on an update? Maybe you have a damaged cord? Check it with a meter. 11.jpg
