Results 1 to 15 of 15
    Dec 2017
    Default CAS4 F10 1L15Y PEROBLEM
    Hello friends,
    This is the story:
    I tried to read CAS4 F10 1L15Y with r270, the programmer has been stuck during reading. I waited a long time but r270 gives the screen ''WAIT''. So i plotted perogramma and tried to read it again but unforunately without success. I then went to the car and pluged cas back in, but the car did nothing at all.
    I have now been able to read eeprom and flash with vvdi prog.
    Can someone tell me whats going on ?
    CAS4 1L15Y Continental 5WK49984JBR
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Why you pfla 512kb. Not should be 1024 kb?
    Mar 2011
    Vilnius,Lithuania
    you are so great keymaker but you don't know that cas4 1L15Y is 9s12xdp512 mcu with 512kb flash size?
    Rito's Avatar
    I have only epron not have flash.. compare to my epron if its lookc fine:
  5. The Following User Says Thank You to Rito For This Useful Post:
    shotaaa (22nd September, 2018)
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by shotaaa View Post
    Hello friends,
    This is the story:
    you flash is ok
    check conection and check fault in car
  7. The Following User Says Thank You to rola1971 For This Useful Post:
  8. #6
    Dec 2017
    Quote Originally Posted by rola1971 View Post
    you flash is ok
    I have ordered new cas and every things works oke now.
    So the peroblem was the cas, im curious what have i done wrong.
    I have checked the adapter that i have used on r270 it was 12v 5a maybe that was the peroblem !?
  9. #7
    I thing not good idea read cas4 with this tool.
  10. #8
    lkjubaking's Avatar
    Feb 2013
    Serbia
    Quote Originally Posted by Brat View Post
    I think the same
    DPF/EGR-OFF , TUNE , FLAPS/SWIRL-OFF , DTC-OFF........
  11. #9
    p1et's Avatar
    Oct 2013
    Yeah I wonder why use R270 for this when you have VVDI Prog which is very good tool, for any type of CAS.
    BTW. How much you paid for new CAS and how long you waited?
  12. #10
    Mar 2011
    Vilnius,Lithuania
    few years ago I try to read cas4 1L15Y mask with xprog with errors, then I try to read with R270 and after few terrible beeps and errors I came back to my old xprog and finished job without problems, of course I made some changes in connections and no more errors in reading-writing appear
  13. #11
    magneto21's Avatar
    Jul 2016
    I agree with "xyznia"
    I have R/W eprom and flash, many cas-4 1L15Y with xprog and
    no problems ,but you have to make right connection.
    regards.
    “The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice.”
  14. #12
    Mar 2013
    Europe
    please post you connection's Xprog with CAS4
  15. #13
    pierre renault's Avatar
    Jan 2013
    I always use R270 in CAS4 1l15y I never had a problem
  16. #14
    Dec 2017
    Quote Originally Posted by p1et View Post
    at that moment i didnt have vvdi prog, Otherwise I would have read with vvdi prog.
    290,- EU for new case.
  17. The Following User Says Thank You to shotaaa For This Useful Post:
    p1et (24th September, 2018)
  18. #15
    droidwayne65's Avatar
    Aug 2015
    North America
    Carpenters, don't blame your tools . R270 can read that chip all day long, with no errors.
