How to use cheap CH341A programmer for read/write 95xxx Eeproms
Page 1 of 9 123456 ... LastLast
Results 1 to 15 of 121
    Newbie dadoCA's Avatar
    Sep 2018
    Bosnia and Herzegowina
    Default How to use cheap CH341A programmer for read/write 95xxx Eeproms
    I hope this will help someone, like it did for me. I must say, this is not my solution, I am just sharing it with you. I used this programmer with success to read and write to 95128 EEPROM.
    1. Buy a cheap CH341A eerpom from Ebay or Aliexpress. This programmer supports two types of eeprom, 24xxx (I2C) and 25xxx(ISP) series, so on the ZIF socket there are labels which indicate where to insert which type of EEPROM. For reading and writing to those eeproms, 3.3 V power is supplied from the programmer its self. But to write and read to automotive 95xxx series eeproms we need to supply 5VDC. Luckly on the programmer there is 5VDC pin which we will be use to get this power from.
    2. Modification 1: 95xxx eeproms are read/write by inserting them to the 25xxx labeled socket and thats where we need to cut the 3.3V trace on the backside on the PCB. Now solder a short piece of wire from 5V pin to pin number one on the socket. Now we have 5V power for our 95xxx eeproms.
    3. Modification 2: Add a 1000uF 16V elco capacitor to the USB power line, positive side of capacitor goes to the plus pole, and negative side of capacitor goes to the minus pole of USB power line. By adding this capacitor we stabilize 5V power, and are getting better readings of eeprom content.
    4. Install CH341A Programmer Software v1.31 and CH 341A drivers. Run the programm, now there are no 95xxx type of eeproms available in the software, select 25xxx, with same capacity as your chip. And thats it.
    I also use AsProgrammer software, it has support for CH341A hardware and 95xxx series eeproms.
  2. The Following 63 Users Say Thank You to dadoCA For This Useful Post:
    al70 (14th January, 2020), AlexDi (14th May, 2022), aliouat50 (26th May, 2019), alquere (25th May, 2022), antonypaul (5th August, 2023), arald25 (6th May, 2022), arthueascii (4th September, 2021), Bacha mini (26th December, 2018), BLUR161 (21st November, 2019), bouba41 (10th December, 2019), ceko1993 (26th September, 2018), Cinellifella (13th October, 2023), Claudio09 (22nd February, 2020), Col19 (16th October, 2019), cone96 (22nd August, 2021), conorka0 (27th November, 2023), damil (14th February, 2022), daninstor (3rd September, 2022), drgelo (11th August, 2023), endyaris (30th April, 2019), eric paris (10th February, 2021), Feridhap (9th January, 2024), galiza (4th October, 2019), ginettoginetto (27th September, 2021), halapa (11th March, 2019), Healow (24th July, 2019), houdiag (29th December, 2018), ICEMANACE (3rd December, 2022), jomberykaso (25th July, 2019), just4upal (16th September, 2018), keymax (12th November, 2018), lorenzo64 (25th August, 2020), luca1272 (13th October, 2023), lvo08 (9th October, 2023), mil912 (3rd November, 2023), milerk (5th May, 2021), mobilni (9th October, 2020), norabitox (7th September, 2023), nyknemesis (29th March, 2019), omar25py (1st April, 2020), pantvas (6th August, 2022), perimo (31st October, 2021), PhilipArt (22nd November, 2019), pjakub (5th February, 2021), ra8686ra (26th January, 2023), reid007 (6th August, 2021), romahic (1st January, 2020), rysiek2 (4th November, 2023), seal777 (18th December, 2022), stutar (14th November, 2021), sunxemx (26th September, 2018), tiguan (26th October, 2019), UKTCHunter (9th December, 2019), ultrasonic (28th May, 2023), veskobx (11th October, 2018), XJTAG (13th November, 2020), xtreme82ita (1st November, 2019), zappaf (28th March, 2020), ~rexdv~ (23rd December, 2023)
  3. #2
    Oct 2013
    Default How-to-use-cheap-CH341A-programmer
    Hi dado CA.
    Could you explain or check pin connections as there seems to be something wrong ! pin 1 of the data sheet for the 95xxx series is the opposite to the one you are showing
    Ignore this post
    The bottom connections are marked different than what they actually are on top.
  4. The Following User Says Thank You to sunxemx For This Useful Post:
    Col19 (3rd June, 2021)
  5. #3
    Sep 2018
    Hello, thank you for the information!
    Will this work to read the dump of the 95640 on the Blaupunkt CD30 ? I need it to decrypt the security code of my car. Thanks again!
  6. #4
    bank's Avatar
    Feb 2017
    Ukraine
    Quote Originally Posted by skna View Post
    It will work for cd30, checked
  7. The Following User Says Thank You to bank For This Useful Post:
  8. #5
    Nov 2018
    This work with SOP8 Clip? Its recommended to desolder the eeprom chip? Or can we use in SRS Airbag without problem?
  9. #6
    Jul 2018
    Good work i will try soon with rcd 300 blaupunkt
  10. #7
    Jul 2018
    i need help here please should i desolder the 95640 chip or use test clip which in no.1 on chip and how should i know it what is the type of chip to use in ch341a software or asprogrammer Please help me
    update (Thanks it is working good with desoldering the chip)
  11. #8
    Sep 2018
    You should always desolder the eeprom chip to get reading without errors. I read the chip twice and save the dumps, then use HxD Software to compare the two dumps with its Analyze->Compare feature. And get some SOIC8 adapter. soic adapter.jpg
    Use As Programmer as it supports larger set of chips.
  12. The Following 3 Users Say Thank You to dadoCA For This Useful Post:
    antonypaul (6th August, 2023), Healow (31st October, 2019), nzjohn (24th February, 2024)
  13. #9
    Sep 2016
    Tell me my brother is possible to work with radio rcd 310 + 510 blaupunkt
  14. #10
    Jul 2018
    working Good
  15. #11
    May 2018
    thank you very much for sharing this. Will it work to read eeprom 93C66 from CID, with this modified programmer?
  16. #12
    Mar 2019
    I use mine on a ST 95160 and never had a problem,great deal and good piece of equipment
  17. #13
    Aug 2019
    Hello, i have eeprom 25080 and he is not detected in software , this model of eeprom is mounted on ecu lucas dcu3r but and eeprom 95080 is mounted on lucas dcu3r 25080/95080 need 5v? On usb programer ch341 stock is not detected.
  18. #14
    Oct 2019
    which modification is the best option to read and write all 24,25,95 chips without errors?
    Adding a 1000uF 16V elco capacitor to the USB power line,
    or cutting 3.3v trace and solder short wire ?
  19. The Following 2 Users Say Thank You to armo For This Useful Post:
    2560172885 (13th June, 2020), stutar (14th November, 2021)
  20. #15
    Jan 2017
    USA ����
    If you were a smart and enterprising young man you could add switches
    To switch back and forth between the 5 v and 3.3v............
    Then it will do all
  21. The Following 10 Users Say Thank You to sleepyrz For This Useful Post:
    adi1 (30th December, 2022), Col19 (20th January, 2020), mixska23 (3rd September, 2020), nzjohn (24th February, 2024), sellingrich (16th January, 2020), stutar (14th November, 2021), thosi187 (4th March, 2024)
