Results 1 to 2 of 2
    May 2010
    Default 95 Fiat Barchetta - Ecu Swap Request
    Can any expert into fiat advice me which tool can program this fiat barchetta with 3 pin connector, the original ecu got damaged by bad coils..
    thr car used sensor key
    multieuscan can’t do the work, just to scan only.
    I need the best tool to code the used pcm to the car or paired the ecu to the car
    Jan 2011
    IASI ,ROMANIA
    I,m not verry sure but if I remember well at this model is enough to fit the pcm on the car and you should wait 5 min with ignition on and the key will self adapt.You can try it but as I say I,m not sure about this procedure and anyway you have nothing to loose
  3. The Following User Says Thank You to gabrielandriev For This Useful Post:
    forumoto (22nd September, 2018)
