Results 1 to 14 of 14
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Default I need fuce atmega 16
    Hi. All
    I need fuce bite atmega 16
    And lock bite atmega 16
    Red atmega 16 upa s orignal
    Atmega 16A
    AU 1636
    Thanks you lb
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
    Aug 2015
    what is oscillator value?(quartz in shiny metal cover near cpu)
  3. The Following User Says Thank You to wodorof For This Useful Post:
    Team dz (18th September, 2018)
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Thank you
    quartz in 8.000 H314
    # Algerian #
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Any HELP
    # Algerian #
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Is there anyone who would prefer that instead of me
    http://eleccelerator.com/fusecalc/fu...chip=atmega16a
    # Algerian #
    Aug 2015
    Try this Configuration 0xDE 0xD9 0xFF
    and make backup of atmega content(flash,eeprom)
    Team dz's Avatar
    Apr 2017
    ALGERIA
    not work my frined any help edit my 2 picteur
    lock and fuce
    # Algerian #
    What are you trying to do?
  10. #9
    Team dz's Avatar
    Apr 2017
    ALGERIA
    I want to program
    IPrem + Flash
    You read normally
    But when I write, I am struck by yellow
    Fuse settings are required
    In order for the programming process to take place
    Hit the top images
    # Algerian #
  11. #10
    Lock and fuse settings are depending on the program running on the Atmega.
    They are not needed for programming. Programming of flash and eeprom is always possible as long ISP is not deactivated.
    If you are 100% sure you have correct flash and eeprom data, erase the chip first.
  12. #11
    Team dz's Avatar
    Apr 2017
    ALGERIA
    thank you
    I have complete data
    Flash + iProm is correct
    When you delete what settings
    Which is programmed by
    # Algerian #
  13. #12
    Are you sure you have correct data? When Atmega is locked, it will read but data is wrong!
  14. #13
    Team dz's Avatar
    Apr 2017
    ALGERIA
    100% sure it is correct read full before closing
    Flash + iProm
    # Algerian #
  15. #14
    Aug 2015
    CKSEL0 False
    CKSEL1 True
    CKSEL2 True
    CKSEL3 True
    SUT0 True
    SUT1 False
    BODEN True
    BODLEVEL True
    BOOTRST True
    BOOTSZ0 False
    BOOTSZ1 False
    EESAVE True
    CKOPT True
    SPIEN False
    JTAGEN True
    ODEN True
    all lock bits TRUE
    did you tried to read Fusebits?
