Results 1 to 3 of 3
    Sep 2018
    Default Need eprom files for peugeot partner 1.9d
    Hi guys,
    i have a peugeot partner 1.9d aa no mnore accesories.
    Have a reseted a coded bsi erasing eprom and coding bsi with vin and accesories.
    I erased too two ecus dcn2 with eprom 95060 and write a white bin from this forum.
    When i try to pair ecu and bsi in peugeot planet ask me for a pin 0000 i bet
    says programing and later pair not possible.
    i dont know how to pair. is same pin as coded in bsi ? when i erase eprom 95180 an telecode manual i dont see how to enter secret code.
    pp2000 generates pin in bsi when its initialized with the vin code and parameters ?
    i need help or two archives for eproms paired bsi ecu and i modifi only the bin.
    now the car starts but no aacc no control in electroventiladores
    when i check in pp2000 dont shows ecu in test
    partner 1.9d
    aacc
    no remote keys
    no inmobiloizer (pump disabled)
    thanks and sorry my english
    Dec 2013
    Post the dump you used ...
    we can take a look
  3. The Following User Says Thank You to sax77 For This Useful Post:
    MARKYTOX (19th September, 2018)
    Sep 2018
    Default Thanks sir
    THANKS
    ECU CODE BABA
    ATTACHED FILES ECU AND BSI
    fan speeds and aacc dont work
