Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    Jan 2012
    Europe
    Copy this file Program files/segger/samples/jflash/projectFiles
    Read again Ti microcontroller uplaod here
  2. The Following 2 Users Say Thank You to RadioChiP For This Useful Post:
    ilen (20th September, 2018), shooting (20th September, 2018)
  3. #17
    here is new reading. can someone check??
  4. #18
    Quote Originally Posted by jackie86 View Post
    can someone tell adresses for 8 bytes that is needed for this mcu??(tms470avf689)
    also adresses for eeprom
  5. #19
    richiebb's Avatar
    Aug 2015
    Argentina
    To get Code you need only 8 bytes from TMS470
    To change code or reset Counter need 64bytes from TMS470
    your dump should look like this
  6. #20
    Jan 2012
    Europe
    Try eeprom _files
  7. The Following User Says Thank You to RadioChiP For This Useful Post:
  8. #21
    richiebb's Avatar
    Aug 2015
    Argentina
    Quote Originally Posted by RadioChiP View Post
    Try eeprom _files
    I doubt it works, the checksum is wrong.
    from the last reading of the TMS the necessary bytes can be extracted.
    But the dump of the eeprom is very bad.......... jackie86 you must read it again .....
    take the eeprom out of the circuit or lift the SDA and SCL pins
  9. The Following User Says Thank You to richiebb For This Useful Post:
    irfa (20th September, 2018)
  10. #22
    Jan 2012
    Europe
    Solder I2c resistor read write again
    3_4 try...........
  11. The Following 4 Users Say Thank You to RadioChiP For This Useful Post:
    irfa (20th September, 2018), jackie86 (20th September, 2018), richiebb (20th September, 2018), shooting (20th September, 2018)
  12. #23
    richiebb's Avatar
    Aug 2015
    Argentina
    3_4 try...........
    good work mate!!!!!!!!!!! 3 and 4 dumps are ok
    THANKS AND REP!!!!!!
  13. The Following User Says Thank You to richiebb For This Useful Post:
    RadioChiP (20th September, 2018)
  14. #24
    Works! Thank you.
  15. #25
    Jan 2012
    Europe
    Which dump ok?
  16. #26
    Which dump ok?
    3rd. I didnt try 4th
  17. The Following User Says Thank You to jackie86 For This Useful Post:
