Hello.
Check this coding: 114B000C09270001880D00E4901A0000000000
First, follow the login procedure with the code: 20795.
Then do the coding.
Hi folks
im looking forsome help in coding my abs it got wiped and I cant get code for it any help would be very appreciated
Wednesday,19,September,2018,18:29:51:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WVWZZZ1KZ9W057201 License Plate: VEZ 6365
Mileage: 169130km-105092mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ9W057201 Mileage: 169130km-105092miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 1010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 021 PP HW: 03G 906 021 AN
Component: R4 2,0L EDC 000SG 4661
Revision: --H08--- Serial number: VWX7Z0H63NA87T
Coding: 0000072
Shop #: WSC 00896 210 89791
VCID: 7CF6CC6C3FEB66A6CD-8028
1 Fault Found:
005705 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 168841 km
Time Indication: 0
Date: 2000.00.00
Time: 01:53:04
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00000100
Torque: 151.3 Nm
Bin. Bits: 00000000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 01316 785 00200
VCID: 74E6E44CD7BB2EE685-8020
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Time Indication: 0
Freeze Frame:
Count: 3
Count: 0
Count: 4608
Count: 195
Count: 49408
Count: 65280
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 77FCD34006CD45FEA0-8022
No fault code found.
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008595955
Coding: F5098E0700041500471400001400000000187F074B00010C00 0000000000
Shop #: WSC 12345 785 00200
VCID: 33642750523569DE5C-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 260608 021 0501
Coding: 00038805
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 070708 054 0402
Coding: 00209069
Shop #: WSC 12345
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD23WU7.
Coding: 0013112
Shop #: WSC 01357 011 00200
VCID: 3D7001686471AFAEBA-8068
Subsystem 1 - Serial number: 6332MSME3D73654AM
Subsystem 2 - Serial number: 6342MSME3D763450D
Subsystem 3 - Serial number: 6352QSME773322056
Subsystem 4 - Serial number: 6362QSME7321394DK
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 CA HW: 1K0 953 549 CA
Component: J0527 051 0101
Coding: 0000012
Shop #: WSC 01279 785 00200
VCID: 73E4E75012B529DE9C-8026
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 964 B HW: 1K0 920 964 B
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0H63NA87T
Coding: 0003403
Shop #: WSC 01286 386 08256
VCID: 2C563C2C8F0B36261D-8078
2 Faults Found:
00771 - Fuel Level Sensor (G)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 147
Mileage: 168636 km
Time Indication: 0
Date: 2000.00.00
Time: 00:15:47
01312 - Powertrain Data Bus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Mileage: 168841 km
Time Indication: 0
Date: 2000.00.00
Time: 01:53:04
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 030708F2002203
Coding: E9801F060002020001
VCID: 356019485C4177EE72-8060
2 Faults Found:
01316 - ABS Control Module
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Mileage: 168841 km
Time Indication: 0
Date: 2000.00.00
Time: 01:53:05
00464 - Control Module with Display for Radio and Navigation (J503)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Time Indication: 0
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1212
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1208
Coding: 0000628
VCID: 387E107C4B538A8669-806C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: 2A5A3A3485FF2816EF-807E
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 168841 km
Time Indication: 0
Date: 2000.00.00
Time: 01:53:07
Freeze Frame:
Voltage: 13.38 V
DU
Temperature: 23.0°C
RPM: 832 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Count: 0
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 10D802087F2D840DC8DAC69010CC
VCID: 78FED07C0BD34A86A9-802C
Subsystem 1 - Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H08 9001
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000756
VCID: 397815787059938E96-806C
1 Fault Found:
01334 - Door Control Module; Rear Right (J389)
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 01:31)--------------------------
ed when i changed my instrument cluster
Hello.
Then do the coding.
