Results 1 to 9 of 9
Thread: PCR2.1 PIN CODE
    Default PCR2.1 PIN CODE
    Hello every body pleas some can get pin from PCR2.1 i have flash and eeprom
    thanks a lot
    Pincode not possible ?
    Jun 2013
    EU
    If flash is not bootmode full read you can’t decrypt eeprom data.
  4. The Following User Says Thank You to morgano For This Useful Post:
    motorsport (21st September, 2018)
    Quote Originally Posted by morgano View Post
    Ok So need read boutmode like Ktag connection with resistor too ?
    Dec 2010
    Quote Originally Posted by motorsport View Post
    Only Smok or AVDI can read pin code + cs from this ECU in bootmode
    Jun 2013
    EU
    Don’t know if ori ktag can extract full boot read, for sure exist tool that can, and also exist people that can decrypt the immo data based on full dump plus eeprom dump.
    Dec 2010
    FOrget about original ktag and people that decrypt the eprom, only AVDI and Smok can do this ECU.
    I have made a lot of this ECU, first you mus unlock eprom by bootmode, after that ECU will be flashed with a unlocked software version (can be done by OBD after eprom unlock), and after this you can read pin+cs
  9. The Following User Says Thank You to jacostanzo For This Useful Post:
    doctore (21st September, 2018)
  10. #8
    Jun 2013
    EU
    Mate, what you did you know, i can tell you there are people able to decrypt eeprom and that is possible take full tricore read by bootmode.
    If you don’t want to believe, it is ok, but both things exists, tool that can read full tricore in bootmode and people with that skills.
    Not only smok or avdi.
  11. #9
    i heard dmtronic can get pin
