Results 1 to 12 of 12
    Apr 2015
    Default VW Passat B7 2012 not switching on, No start
    Hi everone i have VW Passat 2.0 TDI 2012 VIN: WVWZZZ3CZCP052468, car is not switching on when inserting key.
    Removed comfort module to check key coding, key is coded to car And checked fuses.
    ghostrider72's Avatar
    Jul 2012
    UK
    Get VCDS or any other diagnostic to check fault codes first.
  3. The Following User Says Thank You to ghostrider72 For This Useful Post:
    sirjay (21st September, 2018)
    Jan 2016
    Ignition switch, ignition lock, battery...
  5. The Following User Says Thank You to amigokola For This Useful Post:
    doctore (25th September, 2018)
  6. #4
    Feb 2010
    In EEP
    Connect Pin 1 with 16 in OBD2 . Check on diagnostic wath module is damage I thing getaway is faulty, ELV lock or Main relay on BCM module
  7. The Following 2 Users Say Thank You to vasa For This Useful Post:
    doctore (25th September, 2018), sirjay (25th September, 2018)
  8. #5
    Apr 2015
    This what I get from VAS diagnostic report
  9. #6
    Jan 2017
    tunisia
    check the steering lock it may be damaged . if it's the case , try to remove it and unlock it manuelly then you'll be able to make switch on . after , you will need to replace it or just need to make immo off . i try it many times and worked fine .
  10. The Following User Says Thank You to seif For This Useful Post:
    sirjay (28th September, 2018)
  11. #7
    Apr 2015
    Quote Originally Posted by seif View Post
    Thanks buddy unlocking steering lock manually got the car to turn on but wont crank, the car had no ecu client bought used ecu can it be the couse
    of not cranking?
  12. #8
    Jan 2017
    tunisia
    to start the car you need to make immo off to the ecu
  13. #9
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by sirjay View Post
    of not cranking?
    Car will crank with any ECU , with Immo kicking it will run 2-3 seconds and turn off. So it does not matter immo off or On, car has to crack.
  14. The Following User Says Thank You to yugo45 For This Useful Post:
    sirjay (9th October, 2018)
  15. #10
    Jul 2012
    UK
    I had funny situation a while ago. Customer recovered 2011 Audi A5 to us. It was bought from auction with no history on it. No lights on dash at all. No reaction on ignition. We checked everything but couldn’t find the fault.
    Turns out 2 dead remote key. Coded new ones and all started.
    I know A5 is different than passat but worth to check that as well.
  16. #11
    Apr 2015
    Quote Originally Posted by ghostrider72 View Post
    key is fine remote still works and key is still coded to comfort module
  17. #12
    Feb 2022
    Hello , I have same problem , with VCDS I have error on J527 and G85 - no signal/comunication
    How to unlock the steering lock manually ?
