try to put a 120ohm resistor on can h and can l
You CAN'T change it. they are not compatible
Hi to all!
Today I was trying to read with KESS HSFI 2.2 ECU on banch using codecard pinout, but I get wake up error.
Also tried with carprog on bench but does not work...I've readied eeprom on car with carprog. I can't understand why is not working on banch.
The ecu is from an Vectra C year 2003 engine 1.6, Z16XE
I've atached pinout from codecard and look like wirring diagram.
And another question...the HSFI 2.2 ecu can be swaped with HSFI 2.1?
PS: my kess is reworked EU clone
Yes @gsmrepair is right, you cant replace 2.2 ECU with HSFI 2.1.
I had same problem but was my fault, just changed the green and yellow wire
check again if still doesn't work let to know
Not working...I've tried on car and also kess does not read it...wake up error...I've tried kess with hsfi 2.1 and it reads.
Carprog reads this hsfi 2.2 ecu on car.
I don't understand why I can't read flash.
I did not.....because the car starts without problem.
I don't know why I can't read flash....I onl trying to save the flash for my database.
caprog reads flash in car without problem
Yes CarProg only reads EEPROM but not always...
I have original Carprog and it works on some cars and not on others even of the same model. From the company they informed me that the Opel project was never perfected or finished because we are talking of old cars and they do not want to put more work on it... I replied that not all people are rich to have only new model cars but they never replied on this...
This is a very expensive tool for selling as is with unfinished projects! I wish i new it before I bough it...
Best Regards
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
Thanks for info!
But I still need flash for this ECU...somebody can help with flash for it?
