Results 1 to 15 of 15
    Dunker's Avatar
    Yorkshire
    Default UUPROG-S Error CC
    If you have started getting "Error CC" when starting UUPROG-S, Elrasoft has an update out - 15100r2.
    It must be the program phoning home - maybe its been compromised ???.
    Will be interesting if someone can confirm their 15100 is still OK on a computer not connected to the internet.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    Meat-Head's Avatar
    No sorry, I'll just bump your thread as your a great member
    ON/OFF TOPIC/ ASVERTISEMENT:-
    there is is a program called "Scotty patrol" where it pops up a window telling you what is accessing internet
    the free version is IRRTATING, but after a month, question answered and just remove it
    Dunker's Avatar
    Yorkshire
    I've got wireshark logging on a dedicated linux server here. It'll be in the logs somewhere. I'm not overly bothered as mine is a genuine uprog-s. I just thought someone must have an unconnected machine with uprog-s on it. My guess is elrasoft has remotely killed the software. Probably in batches of serials. The response from them when I asked was very fast. Your guess is as good as mine why it timebombed.
  4. The Following User Says Thank You to Dunker For This Useful Post:
    fuzz1 (29th May, 2021)
    I recived original UUPROG-S v2.2.2 and have CC Error on WINXP, WIN7 on Desktop PC and Laptop.
    Can somebody help as Mr Penko does not replay.
    Thanks!
    Solution found - first start must have internet connection!
    Apr 2019
    Quote Originally Posted by tihiuvek View Post
    Hi, I have the same problem, support told me that set correct date in windows but I have the correct date, I have tried in windows 7 and now windows xp and still the same, they only answer me the same thing, thanks
    May 2016
    read me from mr penko
    CC Error
    The problem is appeared when your windows 7/XP is not updated by all Microsoft patches
    Update your windows
    Manual fix the problem by installing the elrasoft digital signing certificate
    1. Unzip es_cert_1021.zip file to a folder
    2. click with the right mouse button over the name of file es_cert_1021
    3. select Install certificate
    4. when Certificate Import Wizard is opened: click next, next, finish buttons
    After that CC Error should be disappeared
  9. The Following 5 Users Say Thank You to SKYTON For This Useful Post:
    Cesarec (29th October, 2021), Fuller (24th March, 2022), fuzz1 (29th May, 2021), Julesd (21st October, 2021), NACER28 (27th July, 2022)
  10. #8
    Apr 2011
    Hi all,
    Installed this as instructions, but still CC error.
    Any advice would be much appreciated.
    Thanks,
    Jules.
  11. #9
    May 2016
    hi in my case i did new instal w7 x32 with this
    Windows 7 SP1 Fr x86_x64 AIO (Dec. 2018) Daz from yggtorrent.nz
    https://www3.yggtorrent.nz/torrent/a...o+dec+2018+daz
    lot of job but work
  12. #10
    Jun 2014
    Serbia
    Quote Originally Posted by SKYTON View Post
    CC Error
    Update your windows
    Thanks mate it's works!
  13. #11
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Tested on XP work pc no internet ever on this pc. After Penko send repair exe now it is working fine.
  14. The Following 3 Users Say Thank You to PSAcars For This Useful Post:
    maybach_ (21st November, 2021), mexanico1971 (21st November, 2021), mossa19 (17th January, 2022)
  15. #12
    Nov 2016
    I have some error i need this file es_cert_1021.zip
  16. #13
    Sep 2010
    hı to all member.i need help for cc error.
    i need es_cert_1021.zip but i did't find it.
    problem solved
    it is in help
  17. The Following User Says Thank You to ali kaptan For This Useful Post:
    alexis266 (22nd January, 2023)
  18. #14
    May 2018
    Quote Originally Posted by mossa19 View Post
    Certificat file for someone who can't find it.
  19. The Following 3 Users Say Thank You to Fuller For This Useful Post:
    alexis266 (22nd January, 2023), Diogo Mello (25th January, 2023), xelos (22nd April, 2022)
  20. #15
    Mar 2011
    I have a solution about CC ERROR, if you still have a problem, I can try to solve it with Team Viewer. Contact PM.
