Results 1 to 5 of 5
    shuvarec's Avatar
    Aug 2018
    Default E64 CAS2 service show up
    Hello
    Need help with check my new dump or advice.
    i use upas with toms for cas2, save original, make 0 km on cas2 and program, change dash and get services when connected.
    What do you think?
    Thanks in advance
    pepi's Avatar
    Is there a dot on the dash ? did you save the original files.
    shuvarec's Avatar
    Aug 2018
    Quote Originally Posted by pepi View Post
    dash right now show just service, original file from dash add
    Jul 2016
    Start the car and turn the steering wheel all the way to the right and then all the way to the left and then back to center and the service light will go off .
    shuvarec's Avatar
    Aug 2018
    If somebody can check original bin. If i read good with out crash ?
