Results 1 to 4 of 4
    Feb 2018
    Default Astra G 2.0T OPC 190HP 267hp
    the next project car ... opel astra g Opc 2.0 turbo 190hp. the car also has turbine modifications gt28, 76 "evacuation route, custome high flow intake, increased gasoline pump, injector 440, fmic with BOV, intake camshaft ...
    the car now runs at 1.3 bar with 267hp and wishes to reach a maximum of 330hp. who post me with software for the car and what does it cost?
    NOX's Avatar
    Mar 2011
    Europe
    How do you plan to ask this thing! ��
    To do a good job
    You have to do it on a dynotest
    And check important parameters:
    AFR
    EGT
    Temp Air
    Etc etc
    Ecu powered, Dtc, Egr, Dpf, Throttle, Flaps, Lambda, Hotstart, AdBlue, Evap, Nox, Speed limiter, Dynotest development.
  3. The Following User Says Thank You to NOX For This Useful Post:
    dominik.m (22nd September, 2018)
    dominik.m's Avatar
    Jun 2009
    POLAND
    And this is proper answer!
    Aug 2012
    Quote Originally Posted by NOX View Post
    To do a good job
    AFR
    EGT
    Temp Air
    Etc etc
    with some logs is also no Problem
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  6. The Following User Says Thank You to icezero2010 For This Useful Post:
    AVDigitale (24th September, 2018)
