Results 1 to 14 of 14
    Mar 2017
    poland
    Default peugeot 207 BSI replacement
    Hi. I need to replace the module BSI because I don't have communication with the steering wheel module, with the airbag, with power steering and the car does not start. after replacing the module everything is ok but the immobilizer is blocking it. So my question is what I need to do to make the car start on the new module bsi . is enough to copy eeprom 95128?
    new bsi i have with identical numbers
    Feb 2017
    Tunisia
    normaly it's enough good luck
  3. The Following User Says Thank You to issam216 For This Useful Post:
    kristofer (25th September, 2018)
    Some possibility they have different sw version even same number anyway you can try BUT backup the eep in safe place. If failed, there are two ways to proceed, virginise the eep and start coding from scratch with known PIN or cloning 9s12DP512 4L00M if you have a programmer.
  5. The Following 2 Users Say Thank You to Zmann For This Useful Post:
    CHIKO (25th September, 2018), kristofer (25th September, 2018)
  6. #4
    Mar 2017
    poland
    this is dump from my bsi . it this bsi auto no start, I dont have communication for airbag , wheel module , Power steering and abs
    it seems to me that the file is damaged but maybe someone will help me
    Mar 2017
    poland
    i add dump but file is empty
  8. #6
    Feb 2017
    Tunisia
    post your new bsi eeprom to virginse it and recode it with your original bsi pin and if need change your vin too
    pin is : S82Y or reverse Y28Y
    VIN : VF3WU5FWC34122685
    for this file i send you original bsi file virgin attached
  9. The Following User Says Thank You to issam216 For This Useful Post:
  10. #7
    Mar 2017
    poland
    i try this and report
  11. #8
    Mar 2017
    poland
    Quote Originally Posted by issam216 View Post
    what is pasword ?
  12. #9
    Mar 2017
    poland
    oki. i have
  13. #10
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  14. The Following User Says Thank You to kiszka For This Useful Post:
  15. #11
    Mar 2017
    poland
    Hi. when I enter the code, I get the information that the code saved in the module is difrent from the code that I enter
  16. #12
    Mar 2017
    poland
    I try S82Y and Y28S
  17. #13
    Mar 2017
    poland
    ok. car start. everything is ok. thanks for your help
  18. #14
    kiszka's Avatar
    Reality of life :
    3:Everyone lies
