Results 1 to 8 of 8
    spiridonas's Avatar
    Default Audi TT 8N8909601 0285001279
    Hi my guys i have the car Audi TT with airbag modul 8N8909601 0285001279 CR16MFR544
    The fault is below, with diagnostic tool i can't erase, via carprog i can clear all fault code error
    but after two days the car come with same fault code error.
    I tried 3 times via carprog but after two days the car come with same fault code error.
    Please how can fix the problem ?
    Many thanks in advance
    00589 - Airbag Igniter; Passenger Side (N131): Resistance too High
    00655 - Seat Belt Tensioner Igniter Passenger Side (N154): Resistance too High
    01217 - Side Airbag Igniter; Front Driver Side (N199): Resistance too High
    00588 - Airbag Igniter: Driver Side (N95) 32-10 - Resistance too High
    00654 - Seat Belt Tensioner Igniter Driver Side (N153): Resistance too High
    01218 - Side Airbag Igniter; Front Passenger Side (N200): Resistance too High
    Meat-Head's Avatar
    Ok
    1) do the Hokey Cokey with both plugs under both seats
    2) do the Hokey Cokey with airbag plug
    3) check live data for resistances of all mentioned parts
    4) launch module out window, download one from ebay
    Feb 2013
    PORTUGAL
    Hi, you need change airbag unit....
    This is an usual internal error in this units...
    Reparation very hard or impossible to do.....
    BR
    Enviado do meu iPhone usando o Tapatalk
  4. The Following User Says Thank You to Safetybags For This Useful Post:
    spiridonas (23rd September, 2018)
    mcm44's Avatar
    Post dump from that unit, I can fix it...
    mcm44's Avatar
    Here it is, repaired dump. Just write it on table, with direct K-line connection to unit, not over OBD.
  7. The Following User Says Thank You to mcm44 For This Useful Post:
    spiridonas (27th September, 2018)
  8. #6
    spiridonas's Avatar
    Hi tried your file, now after two days come back only one fault code error " 65535 Internal Control Module Memory Error "
    Please can you fix ?
    Thanks in advance
  9. #7
    mcm44's Avatar
    Did you write dump over OBD?
  10. #8
    Feb 2013
    PORTUGAL
    Follow 4) step from meat-head!!!!!
