Ok
1) do the Hokey Cokey with both plugs under both seats
2) do the Hokey Cokey with airbag plug
3) check live data for resistances of all mentioned parts
4) launch module out window, download one from ebay
Hi my guys i have the car Audi TT with airbag modul 8N8909601 0285001279 CR16MFR544
The fault is below, with diagnostic tool i can't erase, via carprog i can clear all fault code error
but after two days the car come with same fault code error.
I tried 3 times via carprog but after two days the car come with same fault code error.
Please how can fix the problem ?
Many thanks in advance
00589 - Airbag Igniter; Passenger Side (N131): Resistance too High
00655 - Seat Belt Tensioner Igniter Passenger Side (N154): Resistance too High
01217 - Side Airbag Igniter; Front Driver Side (N199): Resistance too High
00588 - Airbag Igniter: Driver Side (N95) 32-10 - Resistance too High
00654 - Seat Belt Tensioner Igniter Driver Side (N153): Resistance too High
01218 - Side Airbag Igniter; Front Passenger Side (N200): Resistance too High
Ok
Hi, you need change airbag unit....
This is an usual internal error in this units...
Reparation very hard or impossible to do.....
BR
Enviado do meu iPhone usando o Tapatalk
spiridonas (23rd September, 2018)
Post dump from that unit, I can fix it...
Here it is, repaired dump. Just write it on table, with direct K-line connection to unit, not over OBD.
spiridonas (27th September, 2018)
Hi tried your file, now after two days come back only one fault code error " 65535 Internal Control Module Memory Error "
Please can you fix ?
Thanks in advance
Did you write dump over OBD?
Follow 4) step from meat-head!!!!!
