Page 1 of 3 123 LastLast
Results 1 to 15 of 43
    Feb 2012
    Default CGW repair eprom mercedes w207
    Unfortunely my bad when i change mileage by obd I I wanted to move the computer and the cable came out :-(. stupid thing The car start but comunnication with ecu's and few thing
    Please help me repair epprom?
    thanks for advance
  2. The Following User Says Thank You to barth71 For This Useful Post:
    Heykel (16th February, 2019)
  3. #2
    Feb 2017
    Baltic
    what tool you used?
    I have attached repaired dump, try and report.
  4. The Following User Says Thank You to mikkhh For This Useful Post:
    sagie (25th September, 2018)
  5. #3
    Feb 2012
    Quote Originally Posted by mikkhh View Post
    what tool you used?
    I use FVDI but this my fault.
    I write epprom but not succes. Maybe Flash is fault ?
    Will fvdi give advice to flash by obd?
    Do you have correct flash dump
    to this car?
    thank you
  6. #4
    Nov 2015
    write repair my dump ok
  7. The Following 2 Users Say Thank You to Frankcar For This Useful Post:
    barth71 (25th September, 2018), sagie (25th September, 2018)
  8. #5
    Feb 2017
    Baltic
    Quote Originally Posted by barth71 View Post
    to this car?
    thank you
    is diagnostic responding to cgw? Fvdi is the cause why this cgw is dead.
    Are you able to do SCN coding?
    Attached correct fix, try and report.
  9. The Following 2 Users Say Thank You to mikkhh For This Useful Post:
  10. #6
    brend's Avatar
    Oct 2015
    Same where
    to this car?
    thank you
    Repair work only in bench not obd2.
  11. The Following 2 Users Say Thank You to brend For This Useful Post:
  12. #7
    Feb 2012
    Welcome back. Thank you for your help and I'm sorry to write back so late but unfortunately family life etc. :-)
    Of course I will try to download this dump.
    The computer only diagnoses with the gateway and does not show any errors.
    There is no connection with other systems.
    I understand that I have write a dump fix only to epprom and only on bench?
    What epprom is in this CGW. I'm sorry but I have a Mercedes problem for the first time and I do not want to crash anything anymore
  13. #8
    brend's Avatar
    Oct 2015
    Same where
    Yes,rewrite just eeprom in bench .
    Because yours sended eeprom dump active in boot mode.
    Eeprom repair.
    Pass look in pm.
  14. The Following User Says Thank You to brend For This Useful Post:
  15. #9
    Feb 2017
    Baltic
    mc9s12xeq384 motorola mcu in this zqw, my second file should be fixed, first file I did wrong, long day at work . You need good programmer to write this MCU that is it .
  16. The Following User Says Thank You to mikkhh For This Useful Post:
  17. #10
    Feb 2012
    Ok, guys. now I understand everything and I will try tomorrow. And report when it works. I hope :-)
  18. #11
    Mar 2013
    Europe
    Have anyone Manual to read and write with xprog this MCU?
  19. #12
    Feb 2012
    I wrote dump from mikkhh and brend but car is still in boot mode. No indicator , elctric seat etc. and no communication with modules.
    Maybe problem is flash. I read flash . I have option in Xprog a D-Flash and P-Flash.
    D-Flash is empty
    P-Flash is below.
    Please look and help me
    regards
  20. #13
    Feb 2017
    Baltic
    What tool you used to write eeprom ? What tool you used to read flash ? The flash you sent is now corrupt or it is a bad reading with a bad tool... You need good programmer to read write this MCU...
  21. #14
    Feb 2012
    I use XPROG BOX 5.60. When i write epprom and read again is this the same for your dump. However, when it comes to flash, I'm not sure if the reading is ok. Verification in the program is ok but I do not know if it is good. I upload it to the processor in the QFP-112 housing. mask 3M25J. Is it OK?After uploading epprom, unfortunately, it's still the same. Are you suggesting me to use a different programmer?
    I am yelling for help
  22. #15
    Feb 2017
    Baltic
    the flash is read as wrong size and badly corrupt. Car still responds to diagnostic?
