Thiagobr (14th March, 2022)
Hi, thanks
CGW Mercedes W204
C200 W204 CGW A2129004611.rar
EEPROM + FLASH
Hi, thanks
CGW Mercedes W204
EEPROM + FLASH
FVDI is well know that will ruin CGW.
It try to flash CGW, probably write tweaked flash which is not working is most case,
however after flashing it issue a reset command that also reset all modules coding in car, too bad.
Actually fixing is not difficult and can be done in car !!
no need to take out and open CGW and solder wire ...
But need some knowledge in Vediamo or something like that, use SDconnect or passthrough etc.
In vediamo CGW/ZGW is in bootmode, just flash with its original or current latest version firmware,
do proper coding if you have backup, or code it manually if you know which code is correct for your VIN.
I fixed this problem a few years ago, but saw this post new
Thiagobr (15th March, 2022)
My problem came when replacing CGW\ZGW. Everything was ok except the high light that didn't work. I went to do a programming\coding with Autel Maxys 908 pro which failed in the middle of the process and the module crashed. No module does communication.
I've tried flashing with Vediamo. When I go to flash it loads but at the end it shows the following error: "ECU flashing is broken off"
The module is used
I did it with the ignition on.
I read the eeprom and flash with the programmer and apparently the eeprom is good and the flash is bad
Here are the files
Thiagobr (16th March, 2022)
Looks like your W204 is from 2011,
CGW is using 212xxxx
And I think your original CGW should still working.
some modules can be flash in ignition off, actually some should flash in off.
and should check coding in all modules after flash, otherwise there will be some problems or some functions not working.
This problem is kind of easy to fix ! (some coding flashing knowledge is needed)
and can be done in car within 30mins.
If your car battery is healthy, no external power is needed.
If you have online access to do SCN coding it can be done much easier.
A few years ago when I have encountered this problem, no one have solution.
