Cayenne 2012 958
The needles push down and make contact good.
They both can move freely with my hand without much pressure! Which means its not working.
WHen connect to car both needles not working!
Help!
Cayenne 2012 958
Help!
motors dead, need new dash or replace motors. How you took them off?
is this a VDO dash?
Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
wich car or photo from stepper?
Don't forget the magic button !
These stepper motors normally have some sort of spring contacts, check if they make contact.
Or sometimes you push needles to hard and they get stuck to the bottom plate, but that doesn't seem to be your case.
And often these stepper motor break inside, so replace them.
Problem solved, dismantled stepper motor and fixed.
hass42 (13th May, 2022)
