Results 1 to 4 of 4
    Canada
    Default honda fit 15 77960-T5A-A212 CRASH
    i need a help with these files. I purchased first file from tacho soft, but the srs light turned on after a week With internal failure code. Than found a compare from digi and the light came back in a week but didnt scan it
    Ford escape 14 and 17 have similar issues. one came back after 300km and one came back 5 months and the car would not start unless srs module was disconnected with u3000 codes
    little help pls and thank you
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by habs44 View Post
    Wrong section...
    Ford escape with 95640 are know to have hardware issues. 2013-2017 if you clear at first and light went away and came back later on...then don't even waist your time...get a used one and program it to the car or swap info from old to new.. as for the honda fit..it seems like h.w issue too.
    🔥Wacka Wacka 🔥
    Canada
    defenetly wrong section
    kinda failed on uploading my files for the honda fit.. could you take a look and see which one is correct thank for that info on the escapes, one of my clients is pointing figures at me. but this should make him realize its not me
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Just so happen I did a honda fit today with same part # and a 17 escape....what are the odds of both of same day just as you having issue with both.
    Anyways those clear looks weird..I clear your file, 100% tested so if any u3000 codes after then throw it in the garbage.
    🔥Wacka Wacka 🔥
