Results 1 to 2 of 2
Thread: Windows 10
    badapple's Avatar
    Dec 2008
    REQUEST
    11
    Downloads
    136
    Uploads
    Default Windows 10
    Hello all,
    Can someone advise as to how to completely remove Windows 10 & do a fresh install.
    I have tried every option available through Windows 10 & it fails to delete every time.
    I am trying to completely erase the HDD which contains Windows 10 & do a fresh install.
    Any clear instructions anywhere.
    Thank you.
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    dasteph's Avatar
    Nov 2008
    north east
    3
    Downloads
    18
    Uploads
    try the following.
    Method 1 Formatting Your Primary Drive
    Backup any important data. ...
    Insert your Windows installation disc. ...
    Set your computer to boot from the installation drive. ...
    Start the setup process. ...
    Select a "Custom" installation. ...
    Select the partition you want to format. ...
    Format the selected partition. ...
    Install your operating system
