Results 1 to 14 of 14
    DK Veteran magdex's Avatar
    POLAND
    Default BMW F48 2016 Year How Read ISN ?
    I need some info How to read ISN From BMW F48 2016 All key LOST
    ENGINE ECU MEVD 17.2.3 BDC is prepare to add key but I need ISN .
    KTAG . MAGPRO or other software to read ISN
    THX . Regards
    Mar 2017
    read your ecu and post the file
    I think the question here, and on one of my threads, is what tools can we use to read the ECU?
    Mar 2017
    yes friend ktag will read it
    select x series (F48)
    Family 678
    then select plugin 719
  5. The Following 2 Users Say Thank You to ZAHEER For This Useful Post:
    doctore (30th September, 2018), u.s (30th September, 2018)
    do you solve your problem?
    i've had a go at reading the eeprom part of the data from the ECU.
    Can someone please confirm if this is a good read and if you can find the ISN from it?
    Many thanks in advance.
    Apr 2016
    good, contain sk
  9. The Following User Says Thank You to K1nd3r For This Useful Post:
    u.s (17th October, 2018)
  10. #8
    Mar 2017
    [QUOTE=u.s;3398195]i've had a go at reading the eeprom part of the data from the ECU.
    Many thanks in advance.[/QUOTE
    check your PM mate
  11. The Following User Says Thank You to ZAHEER For This Useful Post:
  12. #9
    [QUOTE=ZAHEER;3398514]
    Quote Originally Posted by u.s View Post
    check your PM mate
    Thank you very much for your help mate, worked fine
  13. The Following User Says Thank You to u.s For This Useful Post:
    ZAHEER (29th October, 2018)
  14. #10
    Mar 2017
    Default need isn from ecu dump
    dears , can anyone help me to find the ISN from the dump......its BMW Mini coper
  15. #11
    May 2020
    tot557545@gmail.com
  16. #12
    May 2020
    tot557545@gmail.com
  17. #13
    dragoshu's Avatar
    Aug 2016
    Dacia
    Can sombody extract ISN from Ecu bmw330I 2017 ecu:mg1cs003
    I atach eeprom
    thx
    If I help you dont forget to push thanks button
  18. #14
    dragoshu's Avatar
    Aug 2016
    Dacia
    Solved,isn ecu:
    456AFBC273933B697EE1ABA4B3A3B298
    Sent from my M2101K6G using Tapatalk
