You have solved ?
I need a full bsl backup (flash + eprom) of this ECU:
0281019500 (edc17cp45)
bmw 525d 160kw (2013)
serial programming with bitbox is blocked.
From that moment on I could not communicate anymore with the ecu from obd.
Then I opened the ecu and made a backup with pcmflash (eprom + flash).
Of course, the flash is corrupt now.
I asked then if there is someone who can reconstruct the corrupt flash correctly or if someone has a backup of another car in order to use it and then adapt the ecu (isn + vin adapt)
Enclosed I also put id ecu and VR that we get bitbox.
thank you
You have solved ?
Ecu tuning, DPF, EGR, LAMBDA, ADBLUE and DTC, Remove
Yes. I used the flash of another similar ecu and made BSL reprogramming.
I reassembled the ecu and so restarted the serial communication (enet cable).
then with the bitbox I did:
- recovery procedure with VR files that the bitbox had found
- write data coding
so I restored the ecu to the initial conditions.
Ok perfect
Hello
You write this ecu with bit box and stoped programing....bit box messed the ecu ?
Poslano sa mog BLA-L29 koristeći Tapatalk
