Read 6 bytes from ecu with fvdi
7th byte from key with tango.
Adapt key with fvdi.
Not sure if it works but I think this is your best option for your tools..
Inviato dal mio HTC 10 evo utilizzando Tapatalk
should be possible to read the seven bytes from cluster if u get into service mode with a working key.
fvdi for a3 ic micronas? it s a joke ? stay away with this car
comizelu (10th October, 2018)
2006 ipc fujitsu 2009 micronas
just clone the key these cars as much as you sniff you can damage dashboard or corrupt without the proper tools keyline 884 in 3 minutes cloned and ready to start non remote .
remote learns same time with immo if do by obd?
Nope, thats old one with megamos 48. Remote via comfort electronic
audi S3/a3 2006 safe to read pin with mvp pro/ londsor k518? or should i say no to this job
