Results 1 to 10 of 10
Thread: Volvo xc60
    martis27j's Avatar
    Mar 2012
    Norway
    Default Volvo xc60
    Hi, have some one problem like this before?
    Come Volvo after repairing airbags. Car now not starts and not give key out, telling on speedometer gear is not in park,not right key. On diagnostic i cant reach CEM, another control units also have faults missing connect with CEM. I think, the CEM lost sync with ECU ore is another thing. CEM is 30765624ae.
    Can some one good tips to go right direction.
    martis27j's Avatar
    Mar 2012
    Norway
    Faults stands in PCM :u0167 lost communication with vehicle immobilizer control module. P1608 wachdog malfunction.p0850 Park/neutral switch input circuit. u0140 lost communication with BCM.Also in another units.
    If its CEM modul dead. Are its posible clone unit, if i have just flash and eeprom from CEM. And how to be shore flash and eeprom its ok.
    Someone has an idea?
    soxten's Avatar
    Mar 2013
    Default Volvo xc60
    Sounds like CEM
    Aug 2012
    SWEDEN STOCKHOLM
    Quote Originally Posted by martis27j View Post
    Hi I can support you if you have the right tools by new software online from Volvo server or if you can take it to local dealer because you’re software is crashed !!!
  5. The Following User Says Thank You to Dani1979 For This Useful Post:
    martis27j (9th October, 2018)
    martis27j's Avatar
    Mar 2012
    Norway
    What means crashed. I have Autologic and texa original. Volvo vida and many different programmers. If I try cloning CEM, are be same result as now. Where is the problem? In flash and eeprom?
    martis27j's Avatar
    Mar 2012
    Norway
    No one have info about that problem with CEM. Are is possible clone CEM? or the problem is in flash?
    martis27j's Avatar
    Mar 2012
    Norway
    How is posible fix crashed starting? from where i need to start? Are the problem is in flash or is in eeprom?
    Best Regards Martis
    brend's Avatar
    Oct 2015
    Same where
    You talk like .....repairing airbags......
    With airbag comunication?
    And with srs all ok ?
    Srs without fault?
  10. #9
    Aug 2012
    SWEDEN STOCKHOLM
    Quote Originally Posted by brend View Post
    Srs without fault?
    Hi yes you need to take the earth battery connection out and re-connect it again and try if it work , if it doesn’t work try it again and again 5 or 6 times because you have problem with the CEM unit software and contact me if you need any help
  11. #10
    Aug 2012
    SWEDEN STOCKHOLM
    Hi haved you fix your problem ?? IF no send files for the Cem and ecu and before you take the units out read the abs serial number,Regards Dani.
