Wait wait wait
What do you mean the security light stays on?
On solid?
Or on flashing?
Wait wait wait
On solid?
Or on flashing?
narkeleptk (11th October, 2018)
hello
i mean the anti theft stays on in contine
i am not understand the problem in dashboard or in ECU but i am not open the ecu
thanks for help all
what can i do please?
Do you know there is a bottom that you can actually say thanks for anyone trying to help. some people knows how to say please, start a new thread with same problem but never thanks. Not trying to squeeze it out of him, .
The thanks button is over there looks like this --->>>
Some people just want glory instead of acknowledgment.
Thanks and reputation is earned, not ask for.
Have a nice day.
autochei (11th October, 2018)
If two keys are shown as being programmed then do a parameter reset....
If 0 or 1 key is programmed then its because there is not the minimum number if keys stored.
Use IDS and see live data. It will tell you if its Dash and key or PCM problem...
exactly
what is key count 0? 1? 2?
for ford car to start must be 2 keys stored into car
so if light on dash stay solid continuous on when you put in key you have that one key programmed
you need to add one key more and it should start
if light is blinking/flashing fast then key is not programmed
narkeleptk (12th October, 2018)
hello
but i programed 3 chip cn2,k jmd,tpx2 by tmpro 2 but the same problem
i am not understand the problem in dashboard or in ecu
When you plug in obd programmer what is key count
Quand programmer obd il y a 2 clés programmé
http://www.digital-kaos.co.uk/forums.../2-FORUM-RULES
>>> we are getting far to many posts/threads in languages other than English, we cant moderate them if they are in languages other than English, such posts will now be deleted, please post in English only, use google translate if you have to <<<
Have a nice day.
Prepare two keys, after security access is granted, erase all keys. It will then learn the key in ignition and the security led should be on steady. After about five seconds, repeat the cycle with the second key. Reinsert the first key, turn ignition on and the light should go out. Attempt to start and if all is ok, the car should run.
